CE-34335-8 error tried multiple hdds
Greetings,
I was playing on my ps4 the other day and it turned off. I tried to turn it back on via the power button and it wouldn't. I found that the only way I can turn it on is by putting a disc in. When I do, it gives me error CE-34355-8. I have tried putting in multiple hdds, I have tried to read the original hdd on a PC (which I can just fine), I have downloaded the system OS off Sony website and have installed it on hdd while in ps4 with no change, and I have tried EVERY option in safe mode with no change. What can I try next?
Did it overheat?
由 NR26 完成的
It didn't seem like it did. It just shut off after normal gameplay.
由 domwebhost 完成的
When I turn it on now, (by putting a disc in it) there is no telltale hdd click and the power button doesn't beep. When I press the power button for the 1 sec that it prompts me to, the display turns off but the light is still white. Pressing it again makes no beep and the display resumes with the error message.
由 domwebhost 完成的
That usually happens when something overheats.
由 NR26 完成的
Ok, so let's assume that the system did overheat. What is my next step?
由 domwebhost 完成的
显示更多的5条评论
