跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
I can't access any folder or file on my desktop-won't open!
Whenever I click on a file or folder on my desktop, the system makes a sound and won't allow me to open or access anything there. Has anyone had this happen? I do need to replace my battery.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
What kind of sounds? Does it throw any errors
完成的
添加一条评论
1个答案
I'm suspecting you have a file structure corruption! Restart your system and press Command (⌘)-R to enter macOS Recovery services. Once you're in you want to use the Menu bar to get to Disk Utility, then enter into Disk First-Aid to repair your drive.
Reference: Mac startup key combinations
That should fix things.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Johanna Braat 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 59
