跳转到主内容
加入维修社区 - 创建账户
System: AMD A4-6300 3.70GHz Dual-Core | AMD A58 Chipset | 8GB DDR3 | 1TB HDD | Genuine Windows 10 Home 64-bit
My PC won't boot with an old GPU that I used with a different PC, why?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
It could be that the PSU might not have enough wattage to use the GPU. What hardware are you using?
这个答案有帮助吗?
得分 2
5条评论:
I have 350W and I have 4 drives and a WiFi and Bluetooth board.
完成的
@nytryder26 I mean what names/specs of mother board, RAM, CPU, and GPU. If you can provide that we can see if you might just need to upgrade your PSU.
完成的
@jmehnert System: AMD A4-6300 3.70GHz Dual-Core | AMD A58 Chipset | 8GB DDR3 | 1TB HDD | Genuine Windows 10 Home 64-bit Graphics: AMD Radeon HD 8370D Video | 24X DVD±RW Dual-Layer Drive | Audio: 8 Channel | Gigabit LAN | Card Reader | Keyboard and Mouse Expansion Bays/Slots Total(Free): 2(1) Ext. 5.25" | 1(1) Ext. 3.5" | 3(2) Int. 3.5" | 1(1) PCI | 1(1) PCI-E x1 | 1(1) PCI-E x16 | 2(1) DIMM 240P Connectivity: 6x USB 2.0 | 1x RJ-45 Network Ethernet 10/100/1000 | Audio | 1x VGA | 1x HDMI Chassis: Stylish Gaming Chassis w/350 Watt Power Supply
完成的
So I'm looking at the specs on my end and from what I can tell you're definitely going to need a beefier PSU. My recommendation is a 650W.
完成的
@jmehnert Ok, thanks
完成的
添加一条评论
添加你的答案
NR26 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 18
总计 408
