Don’t turn on
does not turn on. I tried all combinations with the power button but the computer does not respond. when I get off the charger, then the charger heats up as usual, but the computer itself does not react
Try the SMC reset on the mac,
https://discussions.apple.com/docs/DOC36....
If you are comfortable with taking the back off unplug the battery and plug it back in. and try start it again with the charger plugged in.
if this doesn't work you can try plug it into the charger and start it without the battery plugged in.
这个答案有帮助吗?
unfortunately does not help
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 16
总计 274
Have you spilled any liquid, dropped it, or any other damaging things lately?
由 Benjamin Dover 完成的
no, absolutely nothing like that...
由 Irakli Kvirkvelia 完成的
Have you tried replacing the battery?
由 guardian10 完成的
I doubt it is the battery as it don’t power on with the brick and it is only 2 years old.@guardian10
haven't tried it yet@guardian10
显示更多的1条评论
