跳转到主内容
发布于2017年6月,iPad Pro 10.5寸替代发布于2016年的iPad Pro 9.7寸。
What are sensor(s): TT0D TT1D TT2D TT3D TT4D TT5D TT6D TT7D TT8D
Ipad pro 10.5 restarts every 3 minutes. Only known issues are prior damage to an fpc connector on the motherboard and a replaced LCD flex cable. Any ideas about these sensor(s): TT0D TT1D TT2D TT3D TT4D TT5D TT6D TT7D TT8D?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Any suggestions? Ideas?
完成的
添加一条评论
2个答案
已选择的解决方案
I have not heard of these specifically, but if it's indicating these sensors are missing (hence the reboot), and based on the history of this device I would suspect VERY strongly that these sensors are all in the Display. Apple's naming conventions for these sensors are not made public, but they tend to use a pretty normal set of abbreviations. And this would make sense to me (D at the end for Display).
I don't have much in the way of technical documentation for these specific units, but my suspicion is that whatever line the data from sensors is coming in on is the issue. Could be the FPC, or the the replacement cable. Make sure all your solder joints on the FPC are sound. Check Diode mode readings for whatever connector was replaced. You can find expected readings at https://logi.wiki/index.php/iPad_Diode_M...
这个答案有帮助吗?
得分 5
1条评论:
The flex cable wasn't completely soldered.
完成的
添加一条评论
I have similiar problem, can u point out which flex cable?
这个答案有帮助吗?
得分 0
1条评论:
It was the LCD Flex Cable on the back of the display.
完成的
添加一条评论
添加你的答案
Willow 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 54
总计 2,292
