跳转到主内容
JBL Flip 4 portable speaker. IPX7 waterproof bluetooth dual driver speaker that won the CES Innovation Award 2017.
83 个问题 查看全部
Why do the power and sync lights dim when the bass hits?
Used it on my ATV numerous times it worked fine til awhile ago I started hearing crackles each bass thump when I pulled over to check it out (while still playing) I noticed the battery low and for some reason it seemed to drain energy from the LED lights? (Blue power light started to dim each time the bass was hitting same goes for when I turned on the sync light to check if it was just a bad LED bulb) what could be causing this (note the speaker wasn’t mine originally a friend gave it to me and it has been working fantastically til just today)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Whenever bass hits it consumes more current and uses ampere and voltages. If you have heavy speakers compared to the handler it normally happens. You need to use a high capacity transformer. Copper transformers are best for amplification.
这个答案有帮助吗?
得分 1
1条评论:
It’s the portable Bluetooth speaker not their home speakers
完成的
添加一条评论
添加你的答案
Marcos Flores 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 52
