iPhone does not turn on after charging port replacement
Hi. I wanted to make the custom housing for my iPhone SE 2020. Originally it was SE RED PRODUCT, i have changed buttons flex and charging port (SE Black) but after completing the phone does not turn on. I tried wirelless charging and different plugs but there is no vibration or Apple logo show up.
Can you try to help me where should be the problem? Thank you
when you opened the phone before you did anything at all did u disconnect the battery because if you did disconnect the iPhone screen or something you may have fried the phone
由 keith_themuscovyduck 完成的
Yes. The battery came of first and was plugged back last.
由 nizanazo 完成的
was it pulgged in or anything like that
@keith_themuscovyduck no. All components were disconnected. The phone does not turn on after change of charging port. It was working before this assembly
由 nizanazo 完成的
Did you ground yourself from ESD?
由 teardown-er 完成的
显示更多的1条评论
