跳转到主内容
Released in 2016, identified by product number X0H77UA.
1 个问题 查看全部
Wifi and Bluetooth signal very weak
My laptop got repaired 2 days ago and since then both wifi and Bluetooth are showing really weak strength , so weak that if the router is within 1 meter only then internet would work, if I go 3-4 meters away from the router it will remain connected but internet would not work.Same problem with the bluetooth, I have to keep my wireless earphone onto the laptop only then sound will come out of earphone, at merely 3 meters away Bluetooth gets disconnected.What is the problem and how to get it fixed?Did the mechanic loose some wires unintentionally?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @decent_n_devil
Seems as though both of the antenna cables have not been reconnected to the WLAN card (WiFi and Bluetooth are both in this card).
Here's the maintenance and service guide taken from this support webpage for the laptop.
Go to p.54 to view the necessary pre-requisite steps and then the procedure to remove the WLAN card.
You don't have to remove the card, simply gain access to it. On p.55 you can see where the antenna cables are connected to the card and which one goes where i.e. black cable and white cable on the card connectors.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Vikas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 368
