跳转到主内容
The Samsung RF28HDEDB is a 28 cu. ft. refrigerator featuring a Twin Cooling Plus® system, LED lighting, spill-proof slide-out glass shelves, and multiple convenient features, with dimensions of 33 3/4" x 68 7/8" x 35 3/4".
3 个问题 查看全部
Refrigerator set at 7C but is at 3C
I have a Samsung double door twin cooling tefrigerator set to 7 degrees C.
A thermometer inside shows 3 degrees C. What controls the temperature? What sensor if any, d should I replace?
Update (04/18/2022)
RF28HDEDBSR double door
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
Use the Self-diagnostic function during normal operation to check if any sensors are faulty or for any other fault that may be present.
Here's a link to a parts supplier which will help to show where the sensors are located if any are faulty. To find other suppliers that may suit you better, search online using the manufacturer's part number only of the faulty part in the search term of your browser.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Basil Vasili 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 147
