Inconsistent battery charge replacement with iFixit Kit?
I recently replaced the battery in my Retina MacBook 2016 with the corresponding iFixit battery and kit.
I followed the instructions to a tee. After finishing the replacement, the charging would flick on and off.
It recharged to full a couple of times, but eventually stopped charging more than 75%...even though the iFixit battery was detected as new via coconutbattery.
I did an SMC reset and it didn't help.
Clues to note:
-The USB-C port would only be detected if I insert it "right side up". Of course, before this, I could insert it either way.
-I could never tell how full the battery really was, even with coconutbattery. It would be 50% full for an uncommonly long time and then suddenly turn off.
-the laptop no longer detects external displays.
Now the laptop is dead and I can't get it to turn on long enough to see if it's actually charging.
Is this a logic board detection issue or a faulty battery?
Any help would be greatly appreciated!
***Update/Edit:
The laptop now only powers up when plugged in, but the battery won't charge, and powers off when the plug is removed.
FYI - that was the state the original battery was in which prompted the replacement. Makes me think there's some bug with the computer or software. It was old, but still worked fine until I updated to Monterey or the previous version.
I finally got it on long enough to snap these shots from coconut battery.
3条评论
See if you can install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片. You may ned to leave the system on charge for a full day (24hrs).
由 Dan 完成的
I do have it installed! Now that the battery is drained, I'll see if I can turn it on long enough to get a snapshot. Fingers crossed.
由 jjasonham 完成的
@danj Just updated the post with CoconutBattery screenshots :)
由 jjasonham 完成的
