跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for your Sanyo TV.
TV won't register any ports at all. Channel 3 just Fuzz
I have a Sanyo DP26640. When I go to input all ports are checked but nothing I plug in to the TV will show on the screen except the old manual antenna. That picks up local stations just fine. I have a ROKU stick that was working plugged in to HDMI 1 but now I get nothing. Does the channel still have to be on 3? I tried a different ROKU that works elsewhere, I tried plugging in to different HDMI ports. Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Ch 3 is only for things plugged into the ANT jack. Any port inputs like HDMI must be selected as an input. That is what the INPUT button on the remote does (sometimes labeled as something else). The fact that they are all checked on your setup only means that they are available as inputs, but you must select one. Hitting the channel button usually reverts the input to ANT. The Roku I have will cause the TV to change to the HDMI input if I hit any button on the Roku remote. Not all do that so you must change the input to the HDMI port the Roku is connected to.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pamela Haymond 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 341
