跳转到主内容
help did I get scammed?
So i bought this thinking i could fix one of my other ones,
Anyway when it arrived, i plugged it in and nothing,
I thought something was unplugged inside, so I took it Apart nothing was unplugged,
So i tried the keyboard on one of my other laptops, still nothing Nothing
What the heck is going on?
@danj
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What does the onboard battery checker tell you?
完成的
@danj - By nothing i mean it does nothing at all (black screen, no lights, no fan speed)
完成的
添加一条评论
1个答案
已选择的解决方案
There is a onboard battery checker within the battery. locate the LED's and the small button on the battery. What do you get?
The charger plug also has a Green or Amber lit collar. Is it lit and what is the color?
If both are dead then you will need to get replacements to check things.
这个答案有帮助吗?
得分 1
20条评论:
I got no battery,
The charger has a green light
完成的
@beanman56 - OK, this series needs a battery to run. I would also replace the PRAM battery MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement But how much are you willing to put into this system? What is your expectation?
完成的
@danj - A decent macbook for media,
Also i like the keyboard design,
Would a 2007 macbook (NOT PRO) battery work?
idc if the matches
完成的
@beanman56 - Sorry no
完成的
@danj - where can i get one for a cheap price?
完成的
显示更多的15条评论
添加一条评论
添加你的答案
Ben Capehart 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 7
过去 30 天: 7
总计 143
