跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
How bad is this in terms of damage
I recently found this 2017 Macbook Air someone threw out. I didn't realize how new it was until I saw the manufacture date of the SSD and that this thing might be worth saving (it would be the newest computer I've ever found thrown out in my Uni's ewaste). How bad is this board damage? I know the corrosion is very severe and I plan to run this through with lots of swabs and isopropyl. It doesn't turn on (I don't think) but still responds to a SMC reset. Is this worth all of the 90% isopropyl from Walmart or should I declare this thing legally deceased?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I think this is quite bad, its had a chance to stew. Do you have access to a second system so you can check the parts (Display & Battery) If not I would try swapping out a known good logic board. It might end up costing too much to fix.
这个答案有帮助吗?
得分 0
1条评论:
Unfortunately no, I have a 2012 but it’s not with me at this moment. I also don’t know how the other side of the motherboard looks so it could be worse, I might be able to test the drive since that looks good and I have a PCIe adapter
完成的
添加一条评论
添加你的答案
watercannons 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 20
