跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 个问题 查看全部
Logic Board (intel 2.4 GHz) AMD GPU refurbishing
Good morning.
I have a MacBook Pro (17-inch, Late 2011) and I just replaced its Logic Board as its AMD GPU was damaged.
Can someone suggest a suitable place to repair my old Logic Board (intel 2.4 GHz) and refurbish its discrete graphic card (AMD Radeon HD 6770M)?
Below are the pictures recto-verso of my old Logic Board that need fixing. I used it for a few weeks with the AMD GPU bypass fix but the laptop was not worth it only with the intel GPU.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sadly, other than finding a few loose boards in the wild, finding replacement GPU chips and finding someone with the needed skills and tools won't be easy! The last time I looked I couldn't even find the chip new and I would suspect salvaged chips as likely junk!
I had two of these beauties years ago, each one went through three boards all under warranty! And I even replaced the thermal paste to a better TIM. I used TG Pro a.k.a Temperature Gauge at the time to help control things and still ended up replacing the boards on each twice more paying for it!
I loved these systems! as a photographer it offered me a way to see my digital work out in the field. To be clear I was pushing the system hard as it was not designed to handle the heavy graphics load I was putting on it. I ended up getting 15" Retina's for replacements (Late 2013) and upgraded to DG 2015 models which I will continue to use for the time being. And yes, I still shed a tear as the Intel 16" systems today are just not as useful.
So I have the scars to prove this series had glimmer of hope but Apple & AMD failed us! Apple for not servicing its customers with updated models (MIA: 2012 to 2018) and AMD for shipping a poor quality GPU. I suspect the lack of sales because of the failing GPU's didn't help matters!
Enjoy your now working system! I would strongly get a good thermal monitoring app like TG Pro and if you have the skills repaste the GPU with a good quality TIM but becareful! Many people make a mess using way to much or use a conductive TIM or think liquid metal is better (it will damage your logic board & heat sink). And lastly need your fan and heat sink fin area clean!
And of course don't push this system with heavy GPU tasks.
这个答案有帮助吗?
得分 1
1条评论:
Thank you kindly, @danj. I really appreciate your feedback and already installed on all my machines the TG Pro app.
Cheers.
完成的
添加一条评论
添加你的答案
IONEL GRECESCU 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 114
