跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2396 个问题 查看全部
Which direction to pry to remove battery from iPhone 4?
Alright I have followed iFixIt's guide to replace the front assembly on an GSM iPhone 4, but 3 iPhone's I have messed up because of how I removed the battery. The picture on that guide is misleading because it seems like its going the wrong way to pry it. Could someone please instruct me how/which way to pry off the battery from the battery connect, so that it does not break off from the logic board? Thank you so much!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I put my tool on the side farthest from the battery itself / closest to the left hand side when you're looking down on the phone, just a light lift is all that is needed, obviously, make sure you've removed the screw and that weird little bit of metal that is usually there as well ;) [although I just opened one and it was under the screw, if so, don't worry about removing it until you've un-screwed it]
after that just gently go around the battery from all sides to get it off the glue.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Josh Forester 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 894
