跳转到主内容
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
Why does it turn itself off randomly
I recently replaced the housing on my phone after cracking the back glass. Everything is functionally flawless, except for the fact that it'll just turn itself off randomly. Whether or not I move it, whether or not it's plugged in, it'll randomly turn off after a few minutes
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If it restarts every 3 minutes it is more than likely a faulty charge port. You can confirm this by checking the error log; if it mentions “no successful checkins from thermalmonitord since wake” it will be a faulty charge port.
Be careful when ordering a replacement as there are a lot of suppliers who are selling faulty ones that will end up giving you the same problem.
这个答案有帮助吗?
得分 0
2条评论:
The intervals are not consistent, it'll be that, but it can also be once every 10-15 minutes
完成的
@zedphyrm If it wasn’t restarting before the housing transfer you will need to eliminate the faulty part in that housing one by one. A lot of the parts have sensors so you cannot just disconnect them and try the phone. With housing swaps it is usually battery, charge port, power flex.
完成的
添加一条评论
添加你的答案
Zephyr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 67
