跳转到主内容
加入维修社区 - 创建账户
查找 Samsung RF28HFEDB 冰箱的维修信息及其他相关资料。这是一款底部冷冻室的法式对开门冰箱,采用嵌入式设计并配有自动制冰机。本页面涵盖型号匹配 RF28HFEDB** 的相关信息。
Ice Maker Not Working
We purchased a second hand Samsung refrigerator RF28HFEDBSR/AA Everything was working at the time of purchase. We moved it let it sit for a week then installed it. The water dispenser works fine but it is not producing ice.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
12条评论
What model of refrigerator
由完成的 分享
Samsung RF28HFEDBSR/AA
由完成的 分享
@wiccapheonix - Can you take a video of the inside and outside while its trying?
由完成的 分享
I could but theres nothing to show, it doesn't do anything. No sound at all
由完成的 分享
@wiccapheonix - A video would be kind of helpful,
Make sure its not blocked try running a small amount on water though
由完成的 分享
显示更多的7条评论
添加一条评论
1个答案
最有帮助的答案
Hi @wiccapheonix
I can't find a service manual for your model but here's the start of the ice maker troubleshooting flowcharts that may help.
It is for a RF28H series so hopefully it may be close enough to be of some help.
If you can't hear the ice water inlet valve when the ice maker test switch is operated, check the wiring connection to the valve (location is shown in the link - this IS for your model). It looks like there are 3 valves, so it will be a main supply, dispenser supply and ice maker supply. To get water to flow the main has to be operated as well as the desired individual valve i.e. for dispenser it is main and dispenser valves, for ice maker it is main and ice valves. As the dispenser is working obviously the main is as well. So you need to work out which one is the ice water valve
If it seems OK then on p.50 it shows how to remove the ice maker so that you can check if there is water in the tray or not.
Also on p.60 it shows how to get into the diagnostic tests mode which may help.
Sorry I can't help further and especially if the manual isn't relevant to your model
Supplies water to your refrigerator's ice maker and water dispenser.图片
产品
DA62-04027A - Samsung Water Inlet Valve
$158.99
这个答案有帮助吗?
得分 2
2条评论:
Thanks!!! I will give this a go!!!
由完成的 分享
@jayeff - Well said!
由完成的 分享
添加一条评论
添加你的答案
wiccapheonix 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 1,410
