跳转到主内容
System: AMD A4-6300 3.70GHz Dual-Core | AMD A58 Chipset | 8GB DDR3 | 1TB HDD | Genuine Windows 10 Home 64-bit Graphics: AMD Radeon HD 8370D Video | 24X DVD±RW Dual-Layer Drive | Audio: 8 Channel | Gigabit LAN | Card Reader | Keyboard and Mouse Expansion Bays/Slots Total(Free): 2(1) Ext. 5.25" | 1(1) Ext. 3.5" | 3(2) Int. 3.5" | 1(1) PCI | 1(1) PCI-E x1 | 1(1) PCI-E x16 | 2(1) DIMM 240P Connectivity: 6x USB 2.0 | 1x RJ-45 Network Ethernet 10/100/1000 | Audio | 1x VGA | 1x HDMI Chassis: Stylish Gaming Chassis w/350 Watt Power Supply
3 个问题 查看全部
I cant change the RAM usage to 5.0 to 7.2 and I have W10
It can go up to 7.2 but it is locked at 5.0
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi @nytryder26 ,
How much memory is listed when you go to System Configuration > Boot tab > select OS installed if more than 1 installed > Advanced > memory?
To get to System Configuration, press and hold the Win key then press r key, then type msconfig in the box and click OK
这个答案有帮助吗?
得分 3
7条评论:
7.2 is the max but it can only use 5
完成的
@nytryder26
Did you try to change it there?
How much ram is installed? Was amount does it show in BIOS?
完成的
@jayeff It has an 8GB RAM the total is 7.2GB but the limit is 5GB.
完成的
@nytryder26
Is there any memory mapping set in BIOS?
完成的
@jayeff I don't think so
完成的
显示更多的2条评论
添加一条评论
添加你的答案
NR26 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 107
