跳转到主内容
The Dyson V8 Animal is a cordless vacuum equipped with powerful suction that can last up 40 minutes on one charge.
12 个问题 查看全部
Aftermarket Rechargeable Batteries (Safety and Effectiveness)
I've read that replacing a cordless vacuum battery with an aftermarket alternative can be risky.
How does one determine if an aftermarket rechargeable battery will be safe and effective?
I'm wondering about aftermarket rechargeable batteries in general and rechargeable vacuum batteries in particular.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
It most likely would be risky as you don't know the quality of the cells in the battery pack. For example, you could buy cells from Samsung and know they would be of great quality, but you could also buy a nice cheap pack of cells on Ebay, but you have no idea on their quality, lifespan and true capacity. What you could do instead is find a dissassembly video and have a go at replacing them yourself. That way you can replace the current ones with genuine, good quality cells.
Try take a look at this.
这个答案有帮助吗?
得分 1
添加一条评论
There is danger regardless. Reworking Li-Ion pack is risky. The packs are usually difficult to open, and mistakes in rework can lead to fire and explosion. Depending on the BMU, removing a cell could lead to a permanent failure, where the pack will refuse to charge or discharge. Then you're stuck buying a new pack, anyway.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bill Barnum 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 30
总计 279
