Radio and gages only work when pressing brake pedal
Also you only have communication when pressing brake pedal
Please check your brake light switch and the radio power wire (or any others) and verify that the wires have not melted /shorted together. These wires will be located under the dash probably in a bunch. You may have a blown radio and dashboard fuse /cut wires and the brakes are supplying all the power!!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 34
What do you mean communication? Have you checked your wiring? Is there a short somewhere?
由 brandon k 完成的
