Offset Metric Feeler Gauge
I have a 1990 Honda Accord LX two-door coupe. It's time for me to adjust my valves. The detail sticker under the hood says INTAKE: 0.26 mm. EXHAUST: 0.30 mm.
I want to make the adjustment of 0.25, and 0.29 since it has 150,000 miles.
I'm having a hard time finding offset feeler gauges with these measurements. Does anyone know where I can find an offset feeler gauge set that includes metric measurements between;
(0.24mm thru 0.30mm)?
With no skips in between!
Thanks in advance to anyone who can help?
The way you normally use a feeler gauge "kit" is by combining different ones to get to your number, should be accurate enough.
Couldn't find anything that specific when I searched, so if really necessary I'd recommend to get shims instead, in those increments you want and just shape them to your liking.
由 David 完成的
Thank you David for your response
由 Ritchie 完成的
