跳转到主内容
加入维修社区 - 创建账户
Apple 用于取代 30 针底座接口的继任产品。该线缆自 2012 年至 2021 年期间随大多数 Apple 移动产品附赠。
Why are there 8 cables in that Lightning extension?
I'm looking at a Lightning extension cable (with a female plug on one end and a male plug on the other) .
I would like to solder it to a standard Lightning cable (the 8 pin plug) which has 4 cables in it.
But if you look at the photo of the extension, there are 8 cables, in the following order:
black - white - green - yellow - red - purple - orange - blue
The standard 8-pin has 4 cables: gray - green - white - brown
It seems I have to solder every pair of cables from the extenion, to one cable from the 8-pin end.
But which combinations of colors should it be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Ok I have more of a add on question
so the new iPhone has type C… I have a lighting port style sd card reader is like to clip the plug off and solder to a type c male plug on. But every type c end I clip only has 4 wires but lightning has 8.. how do I convert? Or which wires combine?
完成的
@slonik49280 - Get a USB-A to USB-C adapter, then just plug in the USB-A cable end of the lighting cable. Don’t try to breakout the wiring as it’s not that simple.
完成的
添加一条评论
1个答案
A Lightning extension cable should have eight wires that feed through to the other Lightning connector. It appears you are trying to make a conversion to USB-A connection, that cable only have four wires.
这个答案有帮助吗?
得分 0
3条评论:
Thanks for your response.
Yes, basically the other end of that extension is a Male lightning plug that you plug into an iDevice. But it is wobbly and I would like to replace it with a more robust genuine Lightning cable. (essentially cutting the USB-A end of that genuine USB-to-Lightning cable, and soldering the Lightning end onto the extension plug pictured above.
完成的
Why is it that an extension has 8 wires, but the USB-to-Lightning cable has 4?
完成的
@Alex222 - Cables have different purposes!
The number of wires will always be the lessor matching the number of contacts of the connector with fewer contacts. So in your case USB-A is either USB-2 (4 contacts) or USB-3 (8 contacts) wiring.
Presently Lighting to USB-A is four wired. A straight through Lighting cables will have eight wires.
For example there are six different USB-C cable setups! Wait until you try dealing with them ;-{
完成的
添加一条评论
添加你的答案
Alex222 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 34
总计 1,261
