跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
311 个问题 查看全部
Error showing "Unknown part" after battery replacement
After replacing the battery in my iPhone XS Max, an error message "Unknown Part" appeared in the settings.
The Settings>Battery>Battery Health cannot display battery percentage.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
最有帮助的答案
This is normal behavior and is another way for Apple to discourage people from repairing their own devices. A warning is displayed in the introduction of the iFixit guide for battery replacement on this phone. If your phone is acting normally, you can safely ignore this warning.
Keep in mind that Apple continues to make moves like this that hurt the repairability of their products. Replacing the screen, battery, home button (if applicable), and/or front sensor assembly (on iPhones with Face ID) will trigger a message or cause some functions not to work on many iPhones and other Apple devices. Some tools, like the JC V1S, will restore the battery health functions but may not remove the "battery may not be genuine" message.
Serialization of parts is one of the things trying to be fixed by "Right to Repair" laws. You can learn more about Right to Repair under the Advocacy section on the footer of the iFixit website.
这个答案有帮助吗?
得分 4
3条评论:
Not only do you loose battery health - but now I can't download and install new OS updates. I'm stuck on 15.5 since Aug 2022 iPhone 11. Really upset with this.........
完成的
@Junior Hernandez That is a separate issue. I have never experienced lack of OS updates due to a battery issue. Have you tried updating via iTunes/Finder?
完成的
@Junior Hernandez i had the same problem until today. I gave my phone the OS Update with my computer.
完成的
添加一条评论
There's a small board attached to the anode/cathode of the battery.
For a DIY repair, you'll need to transfer this board from the original to the new using a spot welder.
Then a programmer to reset the charge cycle of the battery.
Totally unrealistic/not cost effective for a one off at home, you would need a really good, reputable repair shop to carry this out.
这个答案有帮助吗?
得分 3
2条评论:
After the battery was replaced by a local Fix Shop i noticed the battery unknown message and later found out that the original battery BMS board needed to be install on the new battery. Really upset about this....... Apple thumbs down
完成的
Welding on a lithium battery has the risk of it blowing up in your face. I don’t think a repair shop will offer this any time soon
完成的
添加一条评论
Unknown part battery
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hossam Zanaty 将永远感激不已
浏览统计数据:
过去 24 小时: 26
过去 7 天: 180
过去 30 天: 858
总计 10,885
