跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
My MacBook Pro don't work, SMD burned
Hello People.
I have one MacBook Pro 2015, and now don't work, because have one smd burned, and want to change the smd (eletronic component), and other possible smd burned, but i don't now what this is, to buy a new one, and change. Anyone can help me, please?
Thanks for all guys.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Where is it located on the board?
完成的
Hi Aiden. Sorry, forgot to add the photo.
完成的
添加一条评论
1个答案
已选择的解决方案
The circled component is a tantalum capacitor C7580 - 68UF 20% Case-D2E-SM
这个答案有帮助吗?
得分 2
8条评论:
Thanks a lot. Do you think, i need you change all capacitors? it shows the charger led in green, and the Mac wouldn't turn on, but one day when I tried to restart it again, it started to smell burnt. Do you think there must be something else burned?
The capacitor could be this?
https://mauser.pt/catalog/product_info.p...
OR:
https://pt.aliexpress.com/item/328832743...
完成的
@zwarth - I would just start with this cap and then see what happens. You could also see what happens if you just remove it.
完成的
Hello. I removed the smd capacitor, and the MacBook turn on, but without battery signal. Then i put the smd capacitor (a new one), and still the same issue. Said no battery, and the error code is: PPT001 (I do the reset smc).
This could be the battery is broken, or something in mainboard to replace?
完成的
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
完成的
Hi @danj , already added the image of CoconutBattery result. The image is at top.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Richard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 366
