washer stopped/rubber smell what is it
on permanent press cycle halfway between 4 and rinse, small load.
what could be the problem. it seemed to attempt to start again, but only ran about 5 seconds. 22 year old kenmore
Update (03/30/2022)
this is about where the washer stopped. i tried to run it in a different cycle, but moved it back
4条评论
Hi,
What is the make and model number of the combo unit?
Could be a problem with the belt or the pulley perhaps
由 jayeff 完成的
i pulled off the front panel, i can't see anything...maybe water pump? i'm disabled and not sure i have the hand strength to get the clamps off...and I am in an apartment at 10pm so I can't make much noise at the moment. model 417.98702891. i'm giving it more time to cool down right now.
由 simplymyself21 完成的
the basket seems to move too easy
It's most likely this coupling, between motor and water pump.
https://www.amazon.com/285753A-Coupler-C...
由 Rodney Miller 完成的
