跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
When opening Monitor the screen is blurry and computer non-responsive
When I shut my MacBook Pro for a while and then open it back up, the screen is blurry and computer is non-responsive for a minute or so. Then it gets happy and works perfectly.
It I don’t move the hinges the computer works perfectly. I took it to Apple and it passed the diagnostic tests but the repair estimate was pretty high.
Is it possible there is a loose wire ?
thx
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
A loose wire wouldn't do that. A failing component would.
So if you plug in an external display via the Thunderbolt port (USB-C) when you encounter the issue is the external display showing the proper image Vs the internal? If thats the case the internal display assembly has the issue. If the problem is present on both screens the main logic board has the issue. Both parts are not cheap.
OK, can we dive deeper fixing something deeper. It might be possible, but that will need deeper skills and proper tools to to the task not something a DIY person can do on their own.
Think it this way a GP doctor is not a brain surgeon and you would need the skills of brain surgery to go deeper!
这个答案有帮助吗?
得分 0
2条评论:
I left the computer connected to my external monitor, shut the lid, and then when I opened the lid only the laptop monitor was fuzzy. The external monitor is perfect.
thx
完成的
@cmd41par - Good so we know the issue is within the internal display logic (T-CON board). Sadly you can't replace the T-CON, but you can replace the display assembly! But supply of displays are very tight ;-{
∙ 15" MacBook Pro Display Assembly - Space Grey (16/17), Apple P/N 661-08030
∙ 15" MacBook Pro Display Assembly - Silver (16/17), Apple P/N 661-08031
Here's the guide to replace it 2016 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换
完成的
添加一条评论
添加你的答案
chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 26
总计 618
