跳转到主内容
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Why won't my craftsman hydrostatic riding mower ,
Won't move forward or reverse but when you lift the rear end the tires turn
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Is there any leaks?
完成的
No,..
I parked it, wouldn't start,...was starter solenoid....went to go and nothing ..but when lift rear the tires will thrn
完成的
Only other thing I did was fix a flat tire ...
完成的
添加一条评论
1个答案
已选择的解决方案
Heidi, I am thinking it could be one of two things; you need to push back in a bar in the back that disengages the transmission, or, and more likely, you may not have gotten the pin or key back in when when you fixed the flat tire. Did you see a little pin that slides in along the axle?
This video may help: https://www.youtube.com/watch?v=YC4LnrfE...
这个答案有帮助吗?
得分 1
1条评论:
Thank you, yes it was missing key in the tire, ...had to make one but all good now. Thanks again
完成的
添加一条评论
添加你的答案
Heidi Edgmon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 181
