跳转到主内容
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 个问题 查看全部
iPad 2 replacement battery missing a chip compare to original
Just ordered replacement battery for iPad2, found out that the new battery is missing a chip compare to the original. Anyone knows what is the chip function on the battery? I've checked the ifixit replacement battery, it doesn't have the chip as well. Will it affect the functionality of the battery?
Refer the image, left new battery, right original.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
This will not be a problem.
这个答案有帮助吗?
得分 1
2条评论:
Hmm really? How do you know. I'm really curious the functionality of the chip on the original battery.
完成的
@mirror less I think it tells the iPad that the battery is original.
完成的
添加一条评论
Hi
If I saw this I would be alarmed too but not to worry because you shouldn’t be
The reason why the chip isn’t there is because different battery manufacturers have different ways of designing and managing their battery’s I have had iPod touch screens that look completely different and perform nearly identical to the original(apart from small colour differences)
But to sum it all Up I wouldn’t be worried unless you plug it in and it doesn’t work but that’s rare and it will probably work really really well!
Hopefully I answered your question
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mirror less 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 80
