Can I use/charge a cracked phone
My brother dropped my phone on large gravel, it cracked badly and the screen was kinda coming off but I put it back, can I still charge it?
It should work fine as long as none of the charging circuitry or battery is messed up.
这个答案有帮助吗?
I have a broken iPad Pro 2018, and it still charges and works fine. I think your phone will work. I wouldn’t suggest using it around water, though, because the cracks in the screen can make water get inside the phone.
这个答案有帮助吗?
The battery is usually situated in the backside of the phone so as long as there is no damage to the battery or wires feeding the power from it and its sealed then it should be safe to charge and use I would obviously suggest repairing or getting it repaired asap though.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 199
