跳转到主内容
A1418 | EMC 2889 | Late 2015 | 1.6 GHz dual-core Intel Core i5 or 2.8 GHz quad-core Intel Core i5. Released October 13, 2015.
47 个问题 查看全部
What do I need to purchase if I want to replace the HDD with an SSD?
Looking to replace the HDD in my iMac with an SSD. I have an SSD on hand but want to know do I need to purchase anything such as a temp sensor? I know older models needed some after market temp sensor otherwise the fan would run at 100% all the time. Is this still the same with this model or am I able to replace it without purchasing a sensor? What else would be recommended to make this process easier? I know I will need the little cutter that ifixit sells and some new adheasive. Any recommendations are also welcome.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Here’s the guide iMac Intel 21.5" EMC 2889 Hard Drive Replacement
You don’t need any thermal sensor for your system, But I strongly commend you get the tools and sundry items listed out here iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit And make sure you follow the guide to the letter using the special cutter wheel as many people have damaged their display using the wrong tools.
iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit图片
产品
$89.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dudefoxlive 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 55
