跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Why won't the WiFi services not showing but Bluetooth is working?
When I go to System Preferences -> Network, and WiFi it does not show up as an available network? And I’m unable to run the online diagnostics.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There are a few things that could be messing you up. The first is making sure the AirPort board is properly installed. Sometimes reseating the board can solve things. Follow this guide 交换MacBook Pro13'' Retina显示器 2015早期版本的网卡 Also make sure you don’t have any corrosion on the AirPort or logic board, a liquid spill could have done you in. And lastly, you may need to replace the AirPort board.
这个答案有帮助吗?
得分 0
2条评论:
@danj Thanks for taking your time and responding,
I have a doubt if there a Airport board issue is there any possible that the Wi-Fi and Bluetooth stop working. But in my case the Bluetooth is working perfectly fine but that's not goes for the wi-fi.
And could you suggest any third-party external wi-fi adapters dongles that can work with Macbook Pro.
完成的
@sschaitan10 - Did you try reseating the AirPort board? I would start there.
The Airport board is what converts the signal to a WiFi signal to connect to your WiFi Access Point (AP) Internet Router. As you state you can't see it listed or even in the menu then the adapter its self is likely the issue. They do go bad.
As far as getting an external USB dongle instead of replacing the AirPort board. I haven't seen any that work with macOS as of late. The market for them is almost nonexistent for Mac's. The other option is getting an Ethernet dongle to then connect to a WiFi extender but if you add up the costs its just cheaper getting the Airport board.
完成的
添加一条评论
添加你的答案
Sai Kumar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 194
