跳转到主内容
Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
88 个问题 查看全部
Weird Display on MacBook Pro
Hi guys so I’ve had this weird display of pink and blue flashing lines across my MacBook screen. It suddenly appeared one day when I went to tilt the screen back a little, and has since been a problem. There is no external damage to the laptop so im not sure what has happened. I’ve only been able to temporarily resolve the problem by tilting the screen back and forth until I find a sweet spot, and when I do I just have to leave the laptop open all the time. Though finding a sweet spot has become increasingly difficult. Any fixes for this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If it works by tilting the display, you have a broken display flex cable.
Whole display replacement is required to fix the issue, which is a very expensive repair if you can’t get Apple to fix it for free.
这个答案有帮助吗?
得分 2
5条评论:
Not sure if this is a cable issue (damaged) or more a cable to T-CON solder joint failure. Apple did have a bunch of systems which encountered issues with a poor solder job.
I agree Apple should fix it under an extended warranty. Likely need to ask for a warranty exception to cover this given the age.
完成的
@danj Maybe, but the end result is the same. Anything broken above the short display flex is an expensive repair.
完成的
@tomchai - Very true! If you have to fork it over!
完成的
What are the chances of me being able to fix this problem by myself?
完成的
@Sasha Leira Very high if you spend a lot of money buying new parts. For an in-place fix, no chance at all.
完成的
添加一条评论
All MacBook Pros from 2016 to 2019 suffer from a flex cable issue called "flexgate". This means that the cable that connects the display to the main logicboard is too small and hence, it tears a bit when you open the lid too much, Apple has launched a replacement program for the users to give a free replacement of the faulty display. So you need to take it to an Apple Store and get them to replace the screen. Hope this answer helped :D
这个答案有帮助吗?
得分 0
3条评论:
@honda_fanboy - Not quite true! The 2016/17 13" & 15" models had it bad as the backlight cable was short! The 13" having it the most - thats "FlexGate". The 2018 model and newer had a longer backlight cable which resolved the backlight issue.
But with that said... People have managed to damage the data cables by jamming a paperclip between the case top and the chin plate cracking the glass which in turn damages the cables. That is mis-use not Apples fault!
This looks different as we see an image so this is more like the solder joint issue of the cable to the T-CON board. as the constant tug breaks down the bad solder joint to the point of failure.
完成的
What if my warranty is up? Will they still replace it for free?
完成的
@Sasha Leira - Likely need to ask for a warranty exception to cover this given the age.
完成的
添加一条评论
添加你的答案
Sasha Leira 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 27
总计 700
