跳转到主内容
How to tell SE2 and SE3 apart without opening the device?
Are there any exterior differences between the two for quick identification? I work at a repair shop and people never know what phones they have, so quick identification of models is extremely useful.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
The most easiest way to find out is the model number hidden inside the SIM slot.
iPhone SE 3: A2595(American model), 2782(Japan), 2784(Russia and Middle Eastern model), 2785(China), 2783(Rest of world)
iPhone SE 2: A2275(America), 2298(China), 2296(Rest of world)
完成的
添加一条评论
13个答案
最有帮助的答案
One way would be plugging it in to your computer with coconut battery
And clicking IOS device and then device info,
If it says a15 its the 2022
But if it says a13 its the 2020
这个答案有帮助吗?
得分 7
添加一条评论
Hi
I believe you can plug them into iTunes and it will tell you the device model and IMEI numbers whitch can be translated into the information that you need
Any questions please ask
这个答案有帮助吗?
得分 3
1条评论:
Also a way
but it does not say the IMEI number in itunes it only has a serial number
完成的
添加一条评论
One other way to tell it’s the 2022 model “at first sight” is learn to notice those 3 new colours:
in good light midnight is bluish not black, starlight/silver frame has a creamy/amber tint to it and this year product red is much less bright ;-)
这个答案有帮助吗?
得分 2
添加一条评论
SE 2022 will say 5G instead of LTE
这个答案有帮助吗?
得分 2
添加一条评论
Quickest/most effective way for me is still opening the SIM card tray and checking the model number there.
SE 2nd gen 2020 would have one of these:
A2275 (United States/Canada)
A2296 (Global)
A2298 (China)
SE 3rd gen 2022 will have one of these:
A2783 (International market)
A2595 (USA, Canada, Puerto Rico, Mexico, Saudi Arabia, USVI)
A2785 (China)
A2782 (Japan)
A2784 (Armenia, Belarus, Kazakhstan, Kyrgyzstan, Russia)
You don't need to remember these, just grab whatever model you see on the SIM card tray and quickly Google it. :)
这个答案有帮助吗?
得分 2
添加一条评论
This is the answer I got from our suppler
“The biggest difference from the 2nd generation model - and pretty much only difference in terms of design - is that the iPhone SE 3 features tougher glass on the front and back as briefly mentioned, matching that of the iPhone 13. Otherwise, it's the same shell with the same single rear camera in the top left.”
这个答案有帮助吗?
得分 1
添加一条评论
Thanks for sharing this helpful answer. Now I’m going to bookmark this forum How to tell SE2 and SE3 apart without opening the device?.
这个答案有帮助吗?
得分 1
添加一条评论
Ask for the IMEI number, or model number from the settings menu.
I do this for any device. Amazing how many times people get their device wrong.
这个答案有帮助吗?
得分 1
1条评论:
the amount of times that people have responded to me asking "what phone do you have?" with something along the lines of "Apple 9 Ultra" or something ridiculous like that is astonishing
完成的
添加一条评论
If you didn't know, there's a specific difference between the 2020 and 2022, pretty sure it's a tiny difference in the externals on the bottom of the outside of the phones, near the charging port.
这个答案有帮助吗?
得分 1
添加一条评论
To do this you can check the serial number or go into settings.
这个答案有帮助吗?
得分 0
3条评论:
That involves opening the phone. OP is asking how to tell the difference WITHOUT doing this.
完成的
@Duane Thanks for replying I edited it
完成的
You can find the IMEI on the SIM tray. You can put the IMEI into imei.info to find out.
完成的
添加一条评论
SE 2020 is 4grams lighter... You can weight them.... SE 2020 is 144gr and SE 2022 is 148gr .
这个答案有帮助吗?
得分 0
添加一条评论
to check the model number, go to Settings, General, Model Number and tap on it.
这个答案有帮助吗?
得分 0
添加一条评论
Hello @therealtreezus ! I personally use the CE markings to distinguish the two, on the 2022 and later they've moved this to the frame of the phone, while on the 2020 it is on the back glass. Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
TheRealTreezus 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 69
过去 30 天: 268
总计 7,330
