跳转到主内容
Is it possible to use a 2015 (1st Gen) screen on at 2017 model?
I have a 2015 1st gen screen and an absolutely smashed 2nd gen screen I took out. I did not notice until I started that the home buttons cable was way to short on the replacement screen which was a 1st gen. I was wondering if its possible to just put on a 2015 home button and reconnect it to the body of the iPad
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
have you removed the broke screen yet? if so lay them side by side and see if the ribbon cables match up. if so there is a possibility. but knowing how apple hardware locks stuff id venture to say probably not.
这个答案有帮助吗?
得分 1
2条评论:
I have removed it. The ribbon cables do match up but I am worried about the touch ID. Right now it looks like getting a new one is more worth it than getting a 400$ 2nd gen screen.
完成的
@ashleyfixz if thats the case id make sure you can return it if it wont work. again with apple its hit or miss on other hardware working at all to be honest. there has been alot of problems with trying to use the same stuff for their electronics and having it not work.
完成的
添加一条评论
添加你的答案
Ashleyy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 38
