Low level in right channel when recording LPs
I am digitizing my LPs. I have a Yamaha TT-500U turntable and an old Sanyo receiver. I run the output from my receiver to a computer’s sound card and record with Audacity software.
After recording a bunch of LPs, I noticed (in Audacity) that the level on the right channel suddenly dropped. I checked my turntable and the needle was cockeyed. Not surprising since I haven’t used it in years and had just played a bunch of LPs. Therefore, I replaced the needle on the cartridge (AT90). This didn’t help - right channel is still low.
I checked the recording levels with the radio. That is OK - so problem seems to be related to the turntable. I removed the cartridge and blew out the dust, etc. with compressed air. Still have low levels.
Any opinions on where the problem lies? Cables? Cartridge? Any suggestions on how to further diagnose?
UPDATE: found service manual
Hi,
What is the model number of the Sanyo receiver?
If the radio is internal to the receiver it may be the pre-amp (aka phono) section of the receiver that is the problem (receiver's phono, radio, tape? etc selector switch, the preamp, the pre amp input connections etc) and not the turntable. This is assuming that you're using the phono input to the receiver.
Have you tried swapping the L & R cables over between the turntable and the receiver to check if the problem moves to the Left audio channel?
由 jayeff 完成的
Thanks for the response.
Receiver: Sanyo DCR 250
Radio/tuner is internal to the receiver.
Yes, I am using the phono input to the receiver.
I swapped the cable. Problem moves to the left channel.
I tried another cable with same result.
Seems like problem is with turntable. Repairable? Buy another?
由 David Kalkwarf 完成的
@David Kalkwarf
It might be repairable, but I can't find a service manual or schematic for the turntable.
Maybe check the wiring from the pickup cartridge to wherever it goes and then the cable connections on the output of the turntable.
Low level could be simply due to a dry joint solder connection or a loose connection somewhere.
Post some close up images in your question of the "boards", the cartridge wiring? if visible and the output connections in the turntable, maybe something can be seen.
here's how on ifixit 在已经存在的问题里加入图片
由 jayeff 完成的
@David Kalkwarf How old is the Yamaha turntable you are using?
由 Andrew S 完成的
The turntable is about 35 years old. I suppose it is contrary to the purpose of this site, but perhaps it is time to buy a new one :-)
显示更多的4条评论
