跳转到主内容
Replaced battery 2 months ago, battery not recognised and system slow
Hi there,
I replaced the battery 2 months ago. the laptop was working fine. Out of the blue my laptop is not recognising the battery both in system report and cocunutbattery (see screenshot).
As soon as i disconnect the magsafe the laptop immediately shuts down.
Reset the SMC a couple of times, wiped PRAM, updated to the mac os - still no luck.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Sadly the batteries onboard micro-controller has failed you’ll need to speak with the seller to get a replacement battery.
这个答案有帮助吗?
得分 0
添加一条评论
hey Arun Kumar, you should check the motherboard for something arround the battery area, it maybe the connector or something , well i have seen a problem like this before (not on mac btw) on a yt channel by some technican , he tried to fix some “throwed-away” laptop and one of them is same as your problem , this was cause by some small part inside the motherboard that was broken .
if this didnt help you out then u can search some yt video
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Arun Kumar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 36
