跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
Will NEL/NEE AV7 good replacement of bad cap NEX AV7?
I have blown capacitor also but it was NEX AV7, will it be okay to replace it with NEE AV7 or NEL AV7? I discovered that the 3rd letter indicates a year, will this matter when it comes on replacing one of this? I only have one blown cap btw
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I believe you’re correct that the difference in “prefix” is just manufacture date. Otherwise these are equivalent. It’s a pretty common part on these era Macs. Manufacture date should not make a difference. Just for some context here’s some more info if you really want to make sure it won’t be an issue.
Knowing the values makes this sort of judgement call easier, so if you have details about your intended replacement, those caps are 62μF 11V tantalum caps in a B2S case. I have also seen them referenced using their specific part number TEPSLB21A626MHF8R.
这个答案有帮助吗?
得分 1
添加一条评论
As long as the values and size are correct the age is not critical.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
AJ Calixtro 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 114
