跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
20 个问题 查看全部
Screen flickers on startup - then stops flickering after 2 mins
Hi, my screen flickers for around two minutes on startup with vertical bars showing on the display, then the flickers fade away. It only does this if it’s not recently been used, so it’s as though the flickering goes away after it has warmed up?
Just wondering if anyone has any insight as to why this could be and if it could be fixed?
Cheers,
Tristan
Update (03/16/2022)
Screenshot from coconut battery
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Given the age of the system have you replaced the battery yet?
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
完成的
@danj Thanks for the reply. I've not replaced the battery yet no, I've added a screenshot from coconut battery in the thread.
完成的
添加一条评论
1个答案
If CoconutBattery output is to be believed this is a very old battery! Manufactured 1979-11-30 !!!
Batteries only last about 6 years under normal use. So this is well beyond that.
这个答案有帮助吗?
得分 0
2条评论:
Haha, that’s weird. Other than the glitchy manufacture date, does anything else look off there you can see? Do you reckon the original battery is likely to be worn out and this is a problem the worn out battery could be causing?
完成的
@Tristan Gale - A tired old battery would explain things.
MacBook 12" Retina (Early 2015) Battery and here's the guide Retina MacBook 2015 Battery Replacement
I bet you either use your system mostly plugged in or haven't used it much. Given the age of the system (2015) I would have expected more cycles.
完成的
添加一条评论
添加你的答案
Tristan Gale 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 69
