跳转到主内容
加入维修社区 - 创建账户
主要由沃尔玛销售的 7 英寸平板电脑。除了一个非常普遍的 Micro USB 问题外,这是一款不错的小平板。
How can I replace a power button on a Monster M7 Tablet?
To give a bit of background, I've had the tablet for a number of years now but one day, when 10 year old me decided to pop the back open without knowing what I was doing in order to attempt trying to fix my stuck power button, one thing led to another and my entire switch had popped off and I have never seem it since. So, after having it sit on my shelf for years on end, I've decided to give it a go at trying to get the thing fixed but realized that I still don't really know what I'm doing.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @jarateman ,
Maybe first try just only charging the tablet to check if it will respond to the charger and also that the battery will take and hold a charge.
If it doesn’t hold a charge then “Having it sit on my shelf for years on end,…..” would most likely mean that the battery has become depleted beyond recovery and would need to be replaced. Use the information on the original battery to search online for a replacement LiPO battery i.e. voltage (usually 3.7V), current in mAH and dimensions of battery. (usually a 6 digit number)
After that if you have only lost the Power button actuator, (component that actually operates the switch) once you have replaced the battery (if necessary) you may be able to start the tablet by pressing the power switch inside the tablet. The switch is what the actuator would push to operate it.
Here’s the ifixit Monster M7 平板电脑拆解 guide that may help.
If you get it working you may have to search online how to update the Android OS version installed in the tablet as being an older tablet no doubt it is out of date and will not work with newer apps but it may depend on what you want to use it for.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chase A. 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 21
总计 465
