跳转到主内容
这是由索尼电脑娱乐(现已重组为索尼互动娱乐)生产的游戏主机。PlayStation 4 Slim(CUH-2000系列)是比初版PS4更薄的替代型号,于2016年9月7日正式对外公布。
Stuck on connect dual shock controller and press ps button screen
I am stuck on this screen. I have tried four different cables, went out and bought a new one, three different controllers, tried the reset button, clearing the cache, but it will not connect. The USB port works because it charges my phone when I plug it in. Any help would be appreciated. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
I have same problem will not go past this screen saying connect dual 4cord n prepsps button nothing happens
完成的
Same it won’t work when I press the button
完成的
添加一条评论
27个答案
最有帮助的答案
Your PS4 is requesting a DATA cable, not a charging cable. The difference being, a charging cable is very slow when used for the transfer of data. A Data cable is much faster in terms of mbp/s transfer.
The best solution is probably sitting somewhere in your house. For PS4 this would be any previous flagship device that used USB type 2, use the official cable that came with that, whether it be Sony Xperia, Samsung Galaxy Note/S/A or even M series, Google Nexus devices and so on. For PS5 you can use any Android USB C cable that came with the device. Or you can just order the correct cable.
You can find Data cable in any tech or phone store.
Hope this helps
这个答案有帮助吗?
得分 7
4条评论:
Not even close to the issue but thanks for your help
完成的
I found a data transfer cable and it worked. Other cables charged but didn't connect it. Thank you
完成的
I was told they don’t exist. But I found one that says charging and data transfer?
完成的
Definately did the trick. 2 weak chargers failed which led me here so dug out my sturdy tom-tom one and job done. Thanks ☝️
完成的
添加一条评论
I tried 7 cables, the last one worked, save time and just order the correct cable, search ps4 controller charger cable, you’ll save yourself a lot of time and hassle!
这个答案有帮助吗?
得分 2
1条评论:
Not the cable which is the issue, it's almost like the button is being pressed but the console just doesn't want to fall through with the command. Different controllers wires and everything you can think of was attempted, it's not the wire which is the issue for me
完成的
添加一条评论
i got it to work this way, put it on recovery mode by pressing the power button wait for 2 beeps, then once you see the "please insert the cable screen" unplug the power cable from the back of the ps4 then once your power it on again it should boot back to recovery mode now try to press the ps button again it should work guys
这个答案有帮助吗?
得分 2
1条评论:
Doesn't work, actually had me hopeful pulled the thing out of storage, about to dump some gas on the frigging thing and catch a nice fire show from it.
完成的
添加一条评论
hey,I had the same problem the solution is the cable trust me its the cable its not the ps4 or the controller.go buy new ps4 cable or high quailty wire .
这个答案有帮助吗?
得分 2
1条评论:
You nailed it. Need a better cable
完成的
添加一条评论
The tips on this article may help you resolve this issue.
这个答案有帮助吗?
得分 1
添加一条评论
I don't know if have the same problem or mine is more rare but whenever I connect any controller its shows a little menu saying device not supported ive bought 3 controllers and I've tried 3 cables so what could the problem be because I've tried messaging those guys on tiktok but they don't answer at all
这个答案有帮助吗?
得分 1
添加一条评论
Yep, I am having the same problem. I do think the left USB port is bad, as only certain cables work in it, and a thumb drive I have the boot up software on lights up on the right one, but not the left one. I'm curious what PS4 people are using. I have the Star Wars special edition with the Vader logo on it. I've tried like 10 different cables, 10 different controllers. They all will show the orange soft glow light, and when I push the PS button, it blinks white, goes dark, and then eventually goes orange again. I've unplugged it, restarted, tried the two beeps start up. I've plugged the cords and controllers into other PS4s that work, and they work. It's gotta be the USB ports. That's all I can think of. And if it is, what can you do about it?
这个答案有帮助吗?
得分 1
添加一条评论
I'm going to update this post. People don't seem to understand, it is not the same issue as you with your &&^&^$^ wire has nothing to do with the wire. Not a *!&*^#% thing. &&^& off what the &&^&^$^ wire. It's not the &&^&^$^ wire.
这个答案有帮助吗?
得分 1
添加一条评论
Buy a new controller.
这个答案有帮助吗?
得分 0
7条评论:
Tried 3 different controllers already.
完成的
@thunderrhino Alright, give re-installing playstationOS a go. Heres a tutorial on how todo so. I have a feeling it's some how bricked itsself. Maybe when you were setting it up, the Playstation servers got overloaded or something like that. This can cause it to brick itsself. Heres a tutorial on how to reinstall psOS: https://www.youtube.com/watch?v=G5RhHx2S... - This should work. I wish you luck.
完成的
I have the same problem. Sort of. Just bought a ps4 pro bloke said it was working and he'd initialized it. First off I figured it had a corrupt hard drive. Replaced the hdd. It came with a wired controller and I've got a wireless one too. Turn on the ps4 the wireless controller lights up but won't connect just flashes then turns off. Use the wired controller and get to that screen and push the ps button and nothing happens. Ps4 knows its there because if I push the share or start button a message comes up saying can't use the menu or screenshot. I can boot into safe mode and the wired controller works including the ps button. I've initialized. Initialized and used the re install update. Tried software update (all the updates work and install) the system won't rebuild the database just goes to the blue screen. Everything leads to that blue screen only the wired controller will connect but when I push the ps button nothing happens even though it works in safe mode. I'm at a loss.
完成的
Can't figure it out. Did you manage to get your controller to connect man and get past that screen? Any help or suggestions would be appreciated. Not sure what else I can try 😔
完成的
I’m in the same position I have 2 controllers both them doing it tryed so many wires with pas t doing it reset the controllers aswell and nothing 🥺
完成的
显示更多的2条评论
添加一条评论
If you read my posts I had some major issues with the connect controller screen. Turned out to just be the cord. I had about 6 laying around and only 1 worked.
这个答案有帮助吗?
得分 0
添加一条评论
I blew my PlayStation out really good all around and now it works
这个答案有帮助吗?
得分 0
添加一条评论
Still no working fixes available it's not the wire it's not the controller the Bluetooth chip was replaced so it's not that, the wifi antennas we're replaced that wasn't it, bought a third party device which allows controllers to connect as in wires connection but through the Bluetooth of the USB device will connect to safe boot through the device as it were wired into the console, but still won't allow me to get passed the press the PS button during startup and the console is reformatted so there's no getting past the set up screen without connecting the controller hopefully this helps people understand it's not a simple issue you'd of ran into before, it's a very weird and should of been fixed with everything tried to it. Except its not reformating changing hard drives everything you can think we've tried it, brand new OEM Controllers with brand new OEM wires not for charging for pairing.. all these little fixes are not what are issue is. Thanks for the help, but if your just going to suggest the same things over and over, maybe you should actually read the post and the comments, cause having hopes when I get an email from ifixit having someone comment and it's the same thing as your wire is meant for charging, is honestly insulting at this point with how much some of us have spend on a single console worth less than what we paid trying to solve it's issue.
这个答案有帮助吗?
得分 0
添加一条评论
It's a bad left or #1 USB port. Mines bad and can't connect controller after reset to default settings. I know my port is bad it hasn't worked for a long time. Just didn't realize Sony was simple minded enough to only allow the 1 port to start sequence after reset. #2 USB works great just system won't recognize it. So frustrating!
这个答案有帮助吗?
得分 0
1条评论:
It was saying press ps button on the TV but the controller was just flashing blue then turning off and I couldn't get past that screen
I plugged in a cheap wired controller and that worked
I managed to boot up the PlayStation and went into settings and devices and found the controller
I forgot the controller on the PlayStation then put the controller into pairing mode and it showed up on the PlayStation and it paired and worked
Hope it works for other people
完成的
添加一条评论
I’m having the same issue. Screen says, "Connect the DUALSHOCK 4 using the USB cable and then press the PS button." I’m using the original cables and they work on my friends PS4, so they are ok. If i boot in Safe Mode i still get the same screen message but with SAFE MODE in the top left. I can’t get past it no matter what i try. I have replaced the HDD but still everything is the same.
这个答案有帮助吗?
得分 0
4条评论:
Mine does exactly the same. Cant get past the safe mode screen. If i switch off the playstation at is power bottom. i can start it up using the dual shock remote but keep going back to the connect dual shock remote using usb cable.
完成的
any one finda fix to this? i am having same exact issue
完成的
Have you tried a data cable? Not a charger cable but one that does both. That’s what the message is asking you to do.
完成的
I still haven't fixed this issue and its been over a year for me now. Has anyone got a solution...?
完成的
添加一条评论
is there a way to buypass this screen ?
这个答案有帮助吗?
得分 0
1条评论:
So far I haven't been able to find anything that works. :-(
完成的
添加一条评论
I used a cheap ps4 wired controller from amazon and it worked then reconnected the wireless controller once the ps4 was on and that works for me as its happened a few times
这个答案有帮助吗?
得分 0
添加一条评论
In case anyone hasn’t figured it out.power down the ps4 and restart it with the cable and controller already plugged in. Should work
这个答案有帮助吗?
得分 0
1条评论:
Tried your method but it still doesn't work. :-(
完成的
添加一条评论
tried all relevant comments and still cant get from the screen
这个答案有帮助吗?
得分 0
2条评论:
Same here. Tried ALL the above. Thinking now firmware issue?
完成的
I'm thinking same thing Firmware Issue.
完成的
添加一条评论
I've tried ALL the above to get past the blue screen–Proper data cable, wired controller. Safe mode. Keyboards & mouse. Plugs in, plugs out. Turn off, Turn on. Plus all the wait, wait, waits in between.
Any new ideas??? or
How do I determine a firmware issue if NOTHING can direct me past the blue screen???
这个答案有帮助吗?
得分 0
添加一条评论
An error occurs as shown in the link above. I tested several pads and several cables, but in the end I couldn't solve it. It seems that the USB port on the main unit is broken. Is the motherboard broken?
这个答案有帮助吗?
得分 0
1条评论:
I checked USB port and its ok. I haven't checked Motherboard as i cant see how it could have got broken or damaged from being in the same position and place. I'm thinking its more of a Firmware issue now.
完成的
添加一条评论
mine JUST randomly started just now, i had the same exact problem.. and heres how it first happened:
i switched to a lower end tv, i switched the hdmi and power cords, i turned on the ps4, i tried connecting the controller but it wouldnt connect even though it charges and everything (the orange light is showing too), so i turned off the ps4 with the controller plugged in, i did 3 beeps by accident and didnt realize the ps4 was turning off, i then waited 2 or 3 mins after it officially turned off, i then did the 2 beeps going into recovery mode, i reset the controller a cpl times before unplugging the ps4, i waited a min or 2 before plugging the power cord in, turned on the ps4 again, reset my controller again a cpl times, unplugged it again waited a min or 2 (controller is plugged in this whole process), plugged it again, did the 2 beeps turning off the recovery mode, turned it off and turned it on one more time going into the blue screen, made sure the controller was charging, then i pressed the ps button and it finally randomly connected to the ps4.
im not commenting a solution, im just telling yall the story on how i got mine fixed.
P.s now i have another problem, the controller suddenly died and now it doesnt want to turn on or either charge. I tried plugging the controller into different usb plugs but it still wont charge or turn on. This happened RIGHT after i finally got past the press the ps button screen. smh. its the only controller and charging cable i got right now so i havent tried those options out yet. I just hope that it is only the charging cable. its so weird too because this controller was JUST charging, (thats how i got past the press the ps button) but its like the controller or the charging cable just randomly died. as they were working not too long ago lol idk
这个答案有帮助吗?
得分 0
添加一条评论
Did u ever get it fixed?
这个答案有帮助吗?
得分 0
2条评论:
Sadly I was never able to get it fixed, I still have ps4 sitting in my closet, I've tried absolutely everything. At this point it just stresses me out taking it out.
完成的
Did you try getting a data cable instead of a charging cable? Could be a fault of the controller.
完成的
添加一条评论
The only cable that worked for me was if it was PlayStation brand or someone's elce
这个答案有帮助吗?
得分 0
2条评论:
I've tried everything. Anyone fixed this issue?
完成的
I bought a new Playstation charging/ usb cable (the official one) and plugged it in and it worked after that
完成的
添加一条评论
[image]
I know this sounds a little silly. But just double checking. Is the controller a real PS4 controller and is it the correct cable you are plugging into the PS?
Have you tried charging up the controller and then connecting it wirelessly?
这个答案有帮助吗?
得分 0
添加一条评论
I’m sure i read somewhere that its an issue with one of the components on the board. If i remember i will post the link explaining the issue.
这个答案有帮助吗?
得分 0
添加一条评论
I am getting the same problem as well.
BEFORE ANYONE STATES ITS THE CABLE, ITS NOT THE CABLE I HAVE A NEW OEM DATA CABLE.
So I have tried a new data cable, doesn’t work, this is my 7 year old sons console by the way, and he has just spent £50 of his Christmas money on a new official controller, as the other 2 don’t work. But still doesn’t work. Done safe mode, and if the controller is plugged in, to either port the controller reacts to operate the chosen option. Have tried everything down to full initialisation and reloaded the os from usb, twice on both usb ports. That works fine, but the minute I then ask for fresh set up, plug the controller in (all 3) nothing but flashing white lite then orange to say charging.
Please can someone come back to me with a solution. My son is broken hearted and I can’t afford to go and buy him another console, even used. I feel I really have tried everything. And remember it’s not the data cable!
这个答案有帮助吗?
得分 0
添加一条评论
What worked for me was
I already had a cheap amazon wired controller so I plugged it in
I used that then when the ps4 came on I went into settings and told it to forget the wireless controller then used the data cable in the wireless controller to pair it to the ps4
Hope this helps and you get it sort
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brian Loes 将永远感激不已
浏览统计数据:
过去 24 小时: 22
过去 7 天: 183
过去 30 天: 941
总计 71,521
