跳转到主内容
Xbox One 手柄在2016年随着 Xbox One S 的推出而问世,并增加了对 Windows 10/11 的蓝牙支持。 该手柄修复了 Model 1537/1697 手柄上的许多设计缺陷,更加可靠。该手柄已被改进版 Model 1914 手柄所取代。
164 个问题 查看全部
Looking to fix the right stick click on an Xbox One controller
I have a 1708 Xbox One controller that does not register the right stick click.
I've opened the controller up and looked at the clicker mechanism on the joystick and it seems to make contact just fine and push the button down. But it does not register on a button tester.
I've also installed a new joystick and still see the same issue. I'm assuming this is a board issue at this point? Not sure where to look on the board however.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
It is probably a board issue.
这个答案有帮助吗?
得分 1
2条评论:
Gotcha. Seeing if I can grab a bit more information about it. Is there something that can be replaced on the board or would it require a new board entirely?
完成的
@meattacos You could technically resolder a new part, but there is no way of knowing what part failed, therefore, the board should be replaced.
完成的
添加一条评论
添加你的答案
Francis Carow 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 319
