跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
260 个问题 查看全部
3/4 USB-C slots not working after Battery Replacement
Just replaced my battery with an IFIXIT battery.
Initially, none of the 4 USB-C ports worked.
Googled the issue - said to reset the SMC. Did that.
Now, only 1 of 4 of the USB-C ports are working. Tried resetting again, no luck, still only 1 port is working.
Any thoughts? Advice?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did you try reseating the port cables? I would focus on the side that both ports are not working. Follow the MacBook Pro 15" Touch Bar Late 2016 Battery Replacement follow Step-1 to make sure your system is fully off and down to Step-8 getting toe bottom cover off again.
Jump down to Step-37 and carefully lift off the connection so you can inspect the contacts on both the logic board and cable do you see any bend or damaged? Any dirt stuck inside (use a short blast of can'ed air to make sure) Lastly, is the ribbon cable damaged?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sarah 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 64
