跳转到主内容
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
475 个问题 查看全部
Replacement battery not charged?
Hello!
Im doing a battery replacement for my iPhone and the replacement seems to be depleted? I made sure this was true by testing my old battery and new battery (to make sure I didn't mess anything up) then putting the new battery on a charger. It first gave the normal empty battery charging symbol iphones usually do and came back up after some time on the charger. Is this healthy for the replacement battery to be fully depleted upon receiving it? Should I send it back to IFixIt?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Nothing to be too concerned about, as long as it's charging/discharging normally.
Some batteries arrive empty like yours, some arrive with 90% charge.
You will however lose the battery health section unless you replace the BMS board, OR use a tag on flex and programme via relevant programmer for the relevant manufacturers flex.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Tyler Luce 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 302
