跳转到主内容
这台13寸的MacBook Pro使用四核英特尔十代i5/i7处理器和锐炬Plus核芯显卡,于2020年5月发布(型号为A2251/EMC3348,拥有4个雷雳3接口)
71 个问题 查看全部
Backlight working but no image
Good day, my MacBook Pro has a very weird problem when it boots the screen lit up but no image when I connect it to a external monitor it works fine.. one day I power it down and close the lid plug in the external monitor plug in the power cord the Mac turn on I left it there in chrome shell mode for and extended amount of hour when I return I lift the lid, the screen was working fine on then if I close the lid it goes by back to square 1 does anybody knows what’s happening?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
True you do have a wacky issue!
We’ve seen this before in the older MacBook Pro’s. Your system can support an external display via any one of your Thunderbolt ports when you do the signal load is enough for the internal display to work. In the older models we found the logic board MUX logic was messed up. I’m suspecting that’s the case here.
This will need someone with deeper skills to diagnose and replace the bad components the logic board or you’ll need to replace the logic board.
这个答案有帮助吗?
得分 1
3条评论:
Thank you very much….by the way do u know what causes it
完成的
I'm suspecting a hot ground did you in. You plug in your monitor in a different wall outlet than your system. One of the outlets power wires are reversed (Common & Hot) as the neutral ground line is also tied to common within the breaker power enters in through the wrong side damaging things. I would get a good outlet tester and also check the buildings ground as well.
完成的
Thank you bro
完成的
添加一条评论
添加你的答案
Davion Drummond 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 66
