跳转到主内容
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
165 个问题 查看全部
battery dying quickly after ifixit screen replacement 11 pro max
Hey guys so i replaced the screen with an ifixit led kit and everything went smoothly. Shes is working like a charm and phone looks so nice.
I’ve replaced the screens on my phones (literally my 6, 6s, 7 xr, and now my 11 pro max) build and repair computers and different electronics over the years. Followed steps exactly as the best I could find.
But i noticed that after replacing the screen (with the LED not the oled kit) my battery is dying much much faster than usual. Though the LED does seem to be a lot brighter than the original oled panel, but still.
It stinks there is the adhesive there so it’ll be a pain to remove to just open again, but is this issue common after a replacement? And if so is there a fix for it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
The reason for this is because OLED displays light up every pixel individually so black the pixels are turned off while on LCD displays the backlight is lit up whenever the display is on no matter what color is being displayed so the backlight will draw more power (and I have heard of cases where people replaced there OLED displays with LCD and burn out there backlight circuit from too much power draw) and therefore drain the battery faster.
这个答案有帮助吗?
得分 1
添加一条评论
As mentioned, if you have bought an LCD rather than the OLED. Then this will certainly have an effect on battery performance. This phone isn't designed to run an LCD panel unfortunately.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
fcgarciar1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 61
总计 1,323
