跳转到主内容
The Kenwood Chef A701A is a stand food mixer released by Kenwood.
47 个问题 查看全部
Overheating and smoking after 3 minutes
Have serviced mixer but still not good. Its gets very hot after 3 minutes, can hardly touch motor casing( motor is out of the mixer)
So far I have:
Replaced capacitor
Oiled both bearing felts.
Note there is no choke coil across resistor. Can this cause issue???
Cleaned commutator in drill with 400grit silicon carbide.
Cleaned govener contacts
Used dremel to remove small amount of mica between commutator bars, they were slightly protruding.
New brushes
Checked commutator coil resistance
Screamed at the machine several times, still no improvement.
Any help on any point appreciated
Love this machine
Regards
Eric
Update (03/05/2022)
This is the electrics
Eric
Update (03/05/2022)
I'm did not mark coil housing location when pulling apart. How can I before I have it in the correct alignment. I can see a punch mark is this meant to be used to align parts.
Update (03/05/2022)
Is this an alignment mark?
Update (03/06/2022)
168 and 169 trying to align
Update (03/06/2022)
Are these the scribble line and punch mark
Update (03/05/2022)
Jayeff,
Is this the scrib line and punch mark I need to align.
Regards,
Eric
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @phantomwalker ,
Here’s the service manual for the mixer. On p.8 it describes the re-assembly of the motor.
Hopefully this is of some help.
这个答案有帮助吗?
得分 1
5条评论:
Jayeff, thank you.
I read it but can't see how to ensure the parts(Field Assembly and Drive End Frame Assembly 168 & 169) are aligned correctly.
完成的
This is the parts on red
完成的
@phantomwalker
Bit confused as you highlighted part #176 commutator end frame but mention part #169 drive end frame.
Was there no scribe mark on the commutator end frame and the field assembly so that they can be lined up?
完成的
Jayeff,
Thank you.
Where do I find the scribe mark. What does it look like?
Regards,
Eric
完成的
@phantomwalker
I don't know.
The manual only says to mark the end frames in relation to the "stack" (presumably the field assembly) before removing the motor.
The punch mark is there for some reason so it must be to line up with a mark on the end frame
完成的
添加一条评论
添加你的答案
Eric walker 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 8
过去 30 天: 24
总计 796
