跳转到主内容
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
301 个问题 查看全部
If a brake switch is malfunctioning could it keep a truck from startin
Replaced heater hose assembly on my 1991 Chevy S10 4.3 man, it was spraying water at the intake it started right up.then replaced brake switch it was very difficult to remove and install would start after did nothing all lights work messed with brake switch it started. But now it won't start all lights come on but starter doesn't engage. Could it be the brake switch bent prong maybe
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Hello Donna , i think you are thinking correctly, some cars , especially with bigger engines , won’t start unless the brakes are applied, and the gears are in P or N . but what varies is whether it’s an automatic car or manual , whether for manual - some require clutch pedal to be pressed in to start . also the water in the intake might have messed up slightly, i don’t know if it’s not starting at all, or spinning the starter motor and not starting the engine? . whats important is that your brake pedal switch is a NC ( normally closed) circuit that is pressed all the time when brake pedal is up , making it open circuit , closes the circuit when pedal is pressed ( brake light lit up) . if you did played with the wiring, can you check if the switch has only 2 wires connected or more ?
这个答案有帮助吗?
得分 1
添加一条评论
Hi @junktruck ,
Here’s the wiring diagram from the 1991 S10 service manual showing the starter motor circuit.
With M/T (manual transmission) power is from the ignition key through the clutch switch to the motor start solenoid.
It also shows a crank fuse, but looking at the diagram it is not inline with the solenoid circuit but joins it at connector H1 as indicated in the image
(click on image to enlarge)
这个答案有帮助吗?
得分 1
添加一条评论
Yes replace it, most vehicles now must have the brake pedal depressed to start
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Donna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 48
