跳转到主内容
Repair guides and disassembly information for Google's Pixel 4 smartphone, released in October of 2019.
44 个问题 查看全部
What size Tesa tape should I use for the back panel of a Pixel 4?
What size Tesa tape should I use for the back panel of a Pixel 4? Or will the precut adhesive card do the trick? Thanks in advance.
Update (03/03/2022)
Should the Tesa tape be 1, 2, 4, or 8mm wide? Does anyone know what width the precut card is?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
You can cut the tape into the shape of the border or use B7000
这个答案有帮助吗?
得分 0
3条评论:
Thanks for your reply, but I'm wondering what width the tape should be: 1, 2, 4, or 8mm. I also don't know what width the precut card is.
完成的
About 2mm
Just use the about width
完成的
Or you can use this
[关联产品丢失或禁用: IF356-163]
完成的
添加一条评论
添加你的答案
Mark Mourachian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 166
