跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for tablets produced by Lenovo including the ThinkPad tablet line.
My tab's screen is broken from outside but it is fully fine from innne
My tab Lenovo M7 TB-7305X is broken from outside and inside display is absolutely fine everything is working fine but the tab is given by my college and i have to hand it to them as they gave me fine without any physical and software damage.so i request you to give me a solution for this issue
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Screen display broken my phone
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
Seems as though the touchscreen (supplier example only) is cracked even though you say everything still works OK.
This will have to be replaced as it cannot be repaired.
I cannot find a guide online that shows how to do this but at least you should be able to find the part by searching for 5D68C15471 to get suppliers that suit you.
If doing this yourself may be too daunting contact a reputable, professional mobile phone repair service and ask how much they charge for replacing it: a) if you supply the part and they replace it or b) if they supply the part and fix it.
It may be that it is more expensive than the fine. Even though the part seems inexpensive the labour repair cost may make it expensive.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Krishna Bhosale 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 200
