跳转到主内容
苹果订单编号为MC007LL/A / 27" 2560x1440 分辨率的显示器。
Why is my monitor not turning on?
It seems as if it is not getting any power. I unplugged and plug the monitor back in. When connected to my MacBook Pro it doesn’t do anything and isn’t recognized my MacBook is updated. I also read that the thunderbolt cable could’ve went bad so what do you guys think? Don’t really wanna waste money trying a thousand different things.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Do you have a multimeter?
完成的
添加一条评论
1个答案
If you have a MacBook Pro with a either the original MagSafe or MagSafe2 connector, what happens when you plug in the display cord to power your system does it work (Amber or green LED) using this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片.
Do you hear the fan? in a darkened room when you turn the display on do you see the faint light of the backlight?
这个答案有帮助吗?
得分 0
5条评论:
No there is no backlight whatsoever. Also when MagSafe is plugged in it doesn’t light up.
完成的
@Matthew Burkholder - So either your power cord is bad, the socket in the display is, or the power supply has failed.
Try a different power cord, does the socket look burnt did you have a power outage or lighting storm?
完成的
@danj -I tried a different power cord on it and also tried the power cord that it came with to my windows pc and it powered it on so I know it’s not the power cable the socket didn’t look burnt. Also no I did not.
完成的
Time to open the display and using a DVM check the voltages
完成的
Okie dokie thank you
完成的
添加一条评论
添加你的答案
Matthew Burkholder 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 352
